1 - 6 of 6 Posts
I have looked through many pages of the forums here about clutch problems. I seem unable to locate a resolution to the problem my car has.
The clutch only engages when the pedal is right at the top of travel, I have bled the system and that did not make any difference. Checked for leaks etc and can find none. I have tried putting my foot down going uphill in forth and get no increase in engine revs.
My car is a Mondeo Ghia X 2.0L with 125000 on the clock.
What else can I try ?
try looking for price
MEG Captain
not a lot apart from changing it , but if it is not slipping then i would leave alone until it does slip :L
OK thanks
I assume from your comments that the clutch is on it's way out.
MEG Captain
when you say right at the top of its travel do you mean really at the top or a lot higher than you would like , my 51 plate zetec's clutch is higher than i would like but i am putting up with it :whistling:
1 - 6 of 6 Posts
