The engine (2004 Mondeo 2.0L TDCI, ~115k miles) has trouble cold starting which is getting worse. Even with a fully charged battery now, the engine often requires an additional battery pack to start. Once the engine has started (even briefly) there is no problem restarting it.
Symptoms:
Battery voltage at 12.31 volts [pre start], and 14.52 volts [once started]
When the engine starts a cloud of white exhaust is present at the rear but clears quickly
Exhaust fumes are present in the engine bay for a short time after the engine starts; the fumes are in the region of the turbo
No ECU fault codes
Do the symptoms point towards anything obvious ?
Symptoms:
No ECU fault codes
