Resident LED Guru
Where is the crank sensor located. I suspect i know which one it is, but dont want to get it wrong.
The one i think it is, is at the front of the engine on the block, to the left of the flywheel. I believe this is the most likely suspect as its pointing in towards the flywheel.
Resident LED Guru
thnks mate. Im not actually removing it anyway. Just need to know where it is to wire in the sensor to my new ECU
