I need to take the cruise control controller untit out from under the bonnet to run some cables, distrubing it won't cause any problems will it?
Damo :L
MEG Commander
No, no problems at all as long as you are just lifting the whole unit out and not disconnecting the cable.
I know what you mean it's in the corner above the grommets for the main wiring loom into the engine bay.
Steve
Thanks Steve,
thats the one, just didn't fancying taking it out (not disconnecting) and causing problems as I'd miss CC if it decided not to work....
Amp wires finally getting installed Saturday then
Damo :L
