CURE WIPER BLADE NOISE!!
2165 Views 5 Replies 6 Participants Last post by  kingkong
Done some of my own investigation work on curing dreaded wiper judder!!
I tried new blades, still wiper judder.
Put simply the wiper blades in most cases are pushing too hard down on the screen.
THE FIX ---- Bend the steel arm that connects to the wiper blade up about half an inch to reduce pressure ----
Try it in small increments to avoid damage but it worked perfect for me.
Hope this helps someone.
1 - 6 of 6 Posts
yeah flat blades search ebay for bosch flat blades i got them on my car damn good
Agreed.....cant get any quieter then flat blades.
Keep the blade clean,wipe with vinegar,gets the muck off that you can't see,and helps with a smoother sweep. :L
keep em clean , and loads of glass cleaner on glass too
have the flat ford ones cost silly money, but just glide across the windscreen
1 - 6 of 6 Posts
