The last couple of I have had my mondeo mk3 2.2tdci cut while under hard acceleration. Majority of the time it will flash the glowplug light and give p0251 code.
Fuel rail pressure on crank without imv and injector connected is sitting at 155bar. The car idles and drives fine as long as I don't do any hard acceleration, but it will only when using gear 4,5 and 6.
I checked all fuel lines and recently replaced the leak off pipes and connectors. Fuel filter was done in December.
I'm hoping it's an easy and cheap fix.
