1 - 2 of 2 Posts
Hi
2011 ‘60’ diesel automatic Galaxy
My RH cv joint has fallen to pieces with little warning. Garage are saying they can only get a driveshaft with cv joint attached, not just the joint. I supplied Q drive part 657597341 as recommended by euro car parts and it fits the hub but not the existing drive shaft.
Any other option than £500 on a new drive shaft from Ford?
That part is for the AWF21 Gearbox. Is yours the AWF21 or the MPS6 ?
When you say 2011, is that the registered date? That can vary considerably to the actual build date. The
build date is the important one when buying parts.
You can register on ETIS to find the build date or message me your reg and I will look it up for you.
Quite a few driveshaft options it seems...
This maybe slow to load, give it time... Driveshaft - Front Axle FORD S-MAX/Galaxy 2006- (CA1)
1 - 2 of 2 Posts
