I have noticed a diesel fuel leak coming from the timing case cover area of my mk1 1996 1800cc turbo diesel, the fuel is dripping from the crank shaft pulley area, this makes me think that the fuel pump could be leaking, i was wondering if a leak can occur past the pulley seal on the pump, i can't sea any leaks to the rear of the pump, so i am wondering if this is a common problem on the cav lucas roto diesel pump, are there any specific areas i should be looking at, and if i was to fit a second hand pump as long as the timing marks are set the same would it just be a case of bleedind the pump and injector pipes????, any info appreciated as i am looking at starting it tommorow.
regards
turbod3.
regards
turbod3.
