not my findings at all BunkerMan...the +4mpg never declined as you say its still at 38mpg from 33.9 and I had to drive like a cissy to get that in fact I'm on 42.5 mpg atm after a long drive down to Darlington and back to pick a Mini OnE for my brother...averaged 47.5mpg
..intake valves can get badly gummed up with DI as the fuel cannot clean them...google UK forums +intake valves and read the other forums...
Ford also recommend that I unilaterally use Castrol lubricants and fluids??
its quite simple ..if things are dirty ..they need a clean ...if they are clean ..they do not...so the question then is 'when do you know its dirty? that can really only be answered by using a good product...if there is no change..then your system is clean...but I had the opposite experience...it was dirty and I couldn't find that out til I used the cleaner....absolutely no decline in mpg since...I use BP ultimate before and after
Im aware of how a direct inject petrol,car works. I'm also well aware of the issues regarding carbon fouling. In fact I've recommended people avoid the SCI 1.8 on here for that very reason.
There's a difference between recommending fluids,and recommending not to add what is basically a fuel ( the cleaner) to an engines intake that isn't designed to be fuelled through the intake.
The video above (if anyone watched it) is specific to the Eco boost lineup and there's no reason why it isn't a valid warning. A di Eco boost has high ish compression and a turbo charger. By performing an induction service you rob the engine of its ability to control its own fuelling. The engine is designed to run on precise and sometimes multiple injections at thousands of psi, not something getting sucked through the intake.
They wouldn't advise against it with this specific engine just for the sake of it. Many ford dealerships offer induction servicing and make Good money from it.
In over thirteen years I've never had a fuel economy gain that actually stuck around longer than. Additive leaving the tank. Trust me I've had some crappy and miss treated cars... I'm not saying that if something isn't dirty that it can't happen though.
There's dirt and there's performance hampering deposits. Personally I'd rather use a good quality fuel than spend on additives, but that's just me. I'm not worried about a little dirt and I keep an eye on performance. It's the inside of an engine,not my kitchen, and as long as it's not excessive then a small amount of build up is fine by me.
I take subjective and trip computer mpg with a pinch of salt. Gains of less than ten percent can quickly be had with warmer weather, different driving style, traffic, who you get stuck behind etc. so many variables that it's impossible to judge.
Additives are like religion. You either believe in the magic omnipotent sky fairy or you don't. If someone has faith that the £5 - £20 additive will work then that's up to them. I've had success using Cataclean before. I wouldn't do as they advise though and treat the car every three months.
