1 - 20 of 28 Posts
Craig T
Hi
So i've just been browsing through Autotrader and spotted in the photos of one particular car that the digital speedometer is activated. This is a new 66 plate car, does that mean newer cars are coming out with this enabled?
And does anyone think Ford can enable mine ( i have a Titanium X spec )?
I've seen a few topics on here discussing activating the digital speedometer by themselves using Forscan etc, but don't really what to mess with that, as they say you can turn your car into a giant paper weight if not careful.
Regards
Craig
If the digital speedo is active in the center of the cluster its more likely a Sync3 model.
The Sync2 digital speedo appears on the right hand side of the cluster and is only available when you switch off the lane keeping assist.
I doubt Ford will activate this for you as the last car I part exchanged with the motion locking activated they called me several days later and asked me how I did it as they couldnt turn it off with their system as it was greyed out.
If your near Heathrow or Camberley I can activate for you for a Big Mac meal, it only takes 10 minutes max.
  • Like
Reactions: paul.cud53
Tis Sync 3, just looked at advert and nav screen is the light backkgound, so definitely Sync 3. Also noticed that top left button on dash says 'Sound'. My Sony it is the on/off buttopn for the audio. Wonder why different, or is this another Sync 2/3 difference?
No need for SYNC3 to have this in the middle screen
Newbie
I doubt that it actually relies on Sync3 in any way for this, although fitting Sync3 may have caused the IPC module to need a more recent firmware - which then also came with the digital speedo and also the extra temperature display just under the parking brake warning light.
What would be interesting is for someone to report that they've been able to get it enabled on a sync2 car by asking for the IPC module to be flashed to the latest firmware.
A friend of me flashed the latest firmware on his IPC (SYNC2 Mondeo MK5) and he has the speedometer in the middle screen and the temperature under the parking brake warning light.
He flashed the software with UCDS and the latest calibration files available
Newbie
Hello Mal, if I come up to LHR when you're working and meet you after your shift do you think you could activate a few bits for me? Obviously, I will provide a Big Mac meal and some additional beer funds for your time.
  • Like
Reactions: malford
Newbie
I need all the equipment to do it. I'd like the digital speedo, and TPMS, and switch off the seat belt chime.
I could do it but too busy at this moment in time, very heavy workload for the next couple of weeks
Is this possible without going to the dealer via Laptop / Cable? If so, who has the files?
U definately need UCDS, no other program can flash the modules...
To activate stuff and change map on the car I only need a lifetime license, so I don't use tokens every time, but u need to pay €210, more or less to have an UCDS
Sorry to drag up an old topic but is there anyone in South Wales / Bristol area who could update my Mondeo to the central speed display and the newer narrow speedo & rev counter needles?
Obviously be willing to pay for it. Thanks.
1 - 20 of 28 Posts
