1 - 6 of 6 Posts
My daughter has a 14 plate Cmax Ecoboost but no handbook.
She wants to disable the engine stop/start and cancel the
childproof locking of the rear doors ?
PS her radio/info screen stopped working and rather than pay
the £400.00 plus quoted by the dealer I bought s/h screen on
eBay from a " breaker " for £38.00 and fitted it in 15mins after
watching a YouTube vid !!!
Start stop has a button on the dashboard
Using start-stop
Note: The system is on by default. To switch the system off, press the switch in the instrument panel. The system will only be de-activated for the current ignition cycle. To turn it on, press the switch again.
http://www.fordservicecontent.com/Ford_Content/vdirsnet/OwnerManual/Home/Index?bookcode=O26847&marketCode=US&languageCode=EN&VIN=&userMarket=GBR&div=f
Also for a full handbook
https://secure.ford.co.uk/OwnerServices/Owners-Manual
8 gears or more please
Auto childproof locking is not original Ford spec and dealers won't turn it on.
Someone must have turned it on on your veh using forscan or similar
  • Like
Reactions: drumminman
Isn't the child locks on the rear door function not operated by the rear electric window excluder on the drivers door?
http://www.fordservicecontent.com/Ford_Content/vdirsnet/OwnerManual/Home/Content?bookCode=O25655&languageCode=en&marketCode=US&viewTech=IE&chapterTitleSelected=G1396395&subTitleSelected=G1396400&topicHRef=G1312279&div=f&vFilteringEnabled=False&userMarket=GBR
On old cars it was done manually with the back door open, a lever was moved then later this developed into a keyhole using your car key.
They don't half over complicate things :~)
You could be right there. Depends on model spec of veh.
They are deffo not original ford spec if "auto locking" as speed increases from zero/drive off
1 - 6 of 6 Posts
