My airbag light is flashing 4 times - which according to previous threads and the mirez site means I need to check the pretensioner connections under the front seats.
The mirez website doesn't mention anything about disconnecting the battery before doing this - it only stipulates that you wait 15 minutes from when you switched the ignition off.
I don't want to disconnect the battery because I don't have the stereo security code.
So, is it safe to disconnect and then reconnect the pretensioner connecters whilst the battery is still connected ? - Or is there a risk the pretensioners could go off ?
TIA
MEG Commander
There is no risk, the SRS system is only powered up when the ignition is on plus a short time after its turned off, hence the need to wait 15 mins after the ignition is turned off, no need to disconnect the battery.
Steve
Administrator
As above, hence no mention :L
