I think the CV joint on the drivers side is knacked.
When turning i am getting a cracking/grating sort of noise.
All bushes and arms replaced recently,drop links as well.
When go straight ahaead its fine just when i turn at a junction.
Would you change the joint or full driveshaft?
TDDI Buff
joint if your upto it but ive never been upto it always changed shaft.
on my td the one on the drivers side long one i changed cost about £70 i think but then u pay a garage to change a joint its going to cost you that.
i got some tips if your changing the one on that side save a lot of hastle.
TDDI Buff
well the drive shaft is in 2 parts a metal rod type bit from the gearbox to a bracket with 2 nuts on it then u got the rest of the shaft going to the hub just after this bracket bit u got a chunky metal bit on the shaft hit that and it should seperate the shaft shouldnt be hard atleast then you dont need to empty the gearbox oil plus when u get a new shaft you dont get the rod bit.
hope you understand what i mean lol.
