if you are happy to remove the seat trim then yes its removable as its operated by a metal cable (rather like a handbrake or bike brake cable inner cable) which can be removed and renders teh lumbar support pretty much non existent. being, shall we say, a little on the hefty side for my height, the cable actually BROKE in mine (which is how i worked out how it all works) and for me personally, losing it made the seat a little less comfortable on long trips as i had slightly less support in the lumbar area.Hi. As above - is the lumbar support part in the drivers seat back removable ?? The passenger seat does not have it which makes it ALOT more comfortable than being stabbed in your lower back so is this part simply removable ??
Cheers
