I did the same thing when I opened mine up.
Its hard to get a picture of it in the right place but it sits with the metal legs toward the bottom of the switch. Once you sit it in you will see its essentially just a rocker switch with 2 contact points. The trick is to get the slider switch on the top part of the switch to sit on the copper rocker in the right place when its reassembled
