Evening all.
Hope that someone can help as pulling my hairout.
Galaxy 2006 mk3 ghia manual.
All standard apart from stereo that i canged a year ago.
I bought FORSCAN to get a code for another problem and while at it i found
B1A84-51, PC DTC B1A84 51-2B
Car Configuration Data (Additional Fault Symptom - Not Programmed),
Instrument Panel also says 9A8451 on the self test using the dash.
Forscan does not allow me to clear the code.
thank you in advance
Ste
Hi Mate
I have the exact same galaxy model spec as yours and I am having the same issue as above. Please can you help? did you manage to get to the bottom of it? I have also had an issue where sometimes the car turns over but will not start.
Thanks in advance
Someone changed the speedo unit or changed the configuration files upgrading the stereo etc?
the speedo has been changed few years back (before i bought it) but all was fine until now. I have spoken to a few cluster specialist they have said the cluster is faulty which then generates error codes which can be random and eventually one of them will stop the car from starting which sounds correct as i plugged in a diagnostic machine cleared all the error codes and the car started. so will send the cluster for repair few places on line provide the derive around £100 and i can post in. On my car they are not coded so you can drive the car without a cluster it starts fine.
