What's the point in having HID's in the main beams when they take time to warm up? Wouldn't it be a better idea to just run traditional filaments in the mains? Maybe even higher wattage bulbs with relays and heavier wiring to keep the extra load off the factory wiring?JCTH1 said:thanks bud. Well HID's in my plan for things so if all goes well 6,000k on dipped and 4,500k on main then i might just remove the fogs.
One will have to wait and see.
jcth1
HID's dont take that long to warm up do they? Thought they draw a massive surge of amps then settle....surely they work almost immediately??Glenn said:What's the point in having HID's in the main beams when they take time to warm up? Wouldn't it be a better idea to just run traditional filaments in the mains? Maybe even higher wattage bulbs with relays and heavier wiring to keep the extra load off the factory wiring?JCTH1 said:thanks bud. Well HID's in my plan for things so if all goes well 6,000k on dipped and 4,500k on main then i might just remove the fogs.
jcth1
Spot on :L :L :Lthelongmile said:Proper Proper Proper Foglights will be extremley high intensity and yellow.
If youve ever looked at a street lamp in the fog and wondered why you can see it so well, you'll now know why fog lights are suppost to be yellow.
White fog lights simply reflect the mist that cuases the fog whereas the yellow can really cut through it
but, in heavy fog, you are suppost to drive with sidelights on, and fogs, much like many boy racers do, why? simply because that in thick ass fog, your normal beams will make the fog worse, at least it will seem it to you,
If you drive with sidelights on and fogs, the foglights will illuminate the road Surface and sides, enough for you to see where the car should go, yellow fogs, cut through far further
