1 - 2 of 2 Posts
Hello! First post for my first problem!
My passenger side window has recently stopped going down, I took the panel off and the window is on track.
When the switch is clicked down nothing happens however when you press for the window to go up there is a click.
Does anybody have any idea what could be the problem?
Thanks in advance!
hi i have the same problem i have changed the window switch but i have the same problem the window switch wont work on the passenger side i have checked the fuse i have taken the connector off ie at the door, and still struggling here can i test the motor on the window if so how do i need to take the door apart thanks
1 - 2 of 2 Posts
