1 - 1 of 1 Posts
I have a electrical problem that has just started the rain seems to trigger it if you start the car all the indicators light up continuously not flashing then that will normally clear in the end and they will work correctly but when you turn the engine off and open the door you get the lights on chime but the lights are turned off and all the indicators will keep flashing till you close the door then if you try to lock it with the fob the indicators will flash when they shouldn't on the first lock not dead lock but the doors don't lock then if you leave it a few minutes it will lock correctly has anyone had this problem the carpets all seem dry .
1 - 1 of 1 Posts
