1 - 8 of 8 Posts
Hi, I'm trying to understand how to top up my engine coolant. At the moment the level is around 20mm/30mm below the minimum level. The engine has been off for around 4 or 5 hours when I checked this. So it's cold.
I have read not to mix coolants but how do I know whats in there already? Is it as simple as putting my reg into a well know website and getting some ready mix coolant and just top up with that?
If I don't know what's in there already does it all need to be replaced? Meaning I would have to go to a garage to have this done. The manual does give a spec(wss-m97b44-d) I afraid doesn't mean anything to me.
My car is a 2014 Mondeo Mk4.5, 1.6 Eco Boost, Petrol. UK
Thanks again.
That code should be on the bottle when you buy it, even if you choose cheaper brands it will usually state
meets Ford spec.... etc.
Nice one. I will nip down to my local store and check the bottles for that code before buying. I only noticed the low level today when I went to top up my windscreen washer. Not had any warnings or that.
Thanks again.
As long as it states
WSS-M97B44-D that's the Ford spec and is a pinky / green colour.
If yours isn't pinky / green then it may be better changing it, because you're not supposed to mix colours.
I've just bought 5ltrs of this for my daughters Fiesta.
An obvious comment, but if the coolant is low then it's gone somewhere.
Some places to check for signs of leaking (may have a pink stain) include;
  • the expansion tank (have been known to crack)
  • the 'radiator cap' is apparently a commonly replaced item, if the seal fails it can vent at low pressure, boiling away the coolant
  • water pump
  • thermostat housing
  • radiator and heater hoses (can lead to a damp footwell)
  • engine oil filler cap is also worth a glance to make sure there is no moisture or mayonnaise
Park over a large sheet of cardboard to identify any drips
  • Like
Reactions: AbingDan
Thanks everyone. I will keep a look out for leaks as suggested. Hopefully it's just needing a top up. I noticed today when I nipped into town(around 30 min drive) the level was at the minimum mark.
I got some engine coolant now and will top it up in a few hours when the engine has cooled.
Also, check the O ring in the expansion tank cap, it was broken on my car. Not sure if it was leaking but the levels in the system haven't dropped since it was replaced.
Discussion Starter · #8 ·
When the engine was cold I topped up the coolant to around half way between min and max lines. I checked when the engine was hot and it was just below the max line(30 min town drive). I then checked when the engine was cold it went back to half way and remained at that level the next morning.
Hopefully it just needed a top up but will keep an eye on the level over the next couple weeks.
Thanks again everyone.
1 - 8 of 8 Posts
