Hi,
The car in question is a mondeo mk3 tddi 2.0 (2001).
When I bough the car it had overhearing problems when standing still.
After some searching I found a burnt out connector to the fan. I replaced it together with the sensor it was connected to. After that the fan ran again and no more overheating. I still noticed the temperature reading inceast very slowly (not like it should be). So I replaced the thermostat what fixed that problem.
The problem I still have is that when the car is warm, the engine wil cut out after exact 20sec. While this is happening I have no acceleration control, none. Also the battery light will stay on...
When the car is cold there is no problem. It starts normally and runs great.
I noticed that when I have this problem I can disconnect the coolant temperature sensor, after that I can start again and it will run fine. Ofc when I do this the fan will run and max speed and I will have no temperature readout.
Natualy I changed the coolant temperature sensor witch had no affect at all.
I had the garage read out the ecu and reset it. Reset did nothing. The readout gave a code for coolant temperature reading, egr and fuel pump.
Anyone have some ideas what to check or do?
It feels like an electrical / computer problem.
I'm my mind the egr or the fuel pump should not cauce this kind problem but I could be wrong ofc.
Thanks in advance for any help!
