Possible maf sensor fault. You would need to get a diagnostic done to get the fault code and go from there
Sent from my Pixel 3 XL using Tapatalk
Just had this problem and it was a leak from front intercooler at the plastic bit that's attached to the metal. Ordered a new one from autodoc 74.00 Inc delivery ford wanted 500Hello all! Could anyone give me a hint as to where to find the fault causing this issue?
2.0 TDCi Titanium X, 156k miles.
Accelerating uphill, loss of boost, engine malf light comes on. No other issues, no smoke, no knocks or bangs, still drives fine, just no boost.
Engine off and on and fault cleared, but will happen again next time I accelerate hard.
RAC been out, no fault codes, turbo hoses OK, no visible issues under bonnet, RAC could not determine cause.
I can take it local garage, but was hoping there may be a few obvious things to check first that a numpty with a socket set can do at home.
Thanks all.
