I been here a few times before to find out information on faults for friends, but now I actually own a Ford I suppose it was just a matter of time before I needed help myself
I currently have a Focus 1.6 zetec tdci 61 plate mk3. It's done 50k miles and I generally do any work on cars myself having worked in maintenance for the last 15 years or so.
The fault I have is the dreaded 'engine malfunction service now' warning, and although I have seen various topics posted about this, I am yet to see one that describes the nature of the fault I have.
The first time I saw it I was trying to overtake someone on an A road, and when I accelerated to build up speed before pulling out, the warning came on and the car went into limp mode. This was about 1 year ago. I stopped the car and checked in the engine bay for any loose, burnt, things and low levels etc, and decided the oil may need a top up. When I got back in the car and started it up the fault was gone and limp mode no longer active.
The fault has popped up a few times in the last 12 months but I couldn't quite put my finger on what was causing it. I have now figured out that when I accelerate heavily, in any gear, the fault appears, limp mode comes on, and the only way to clear the fault is to turn off the ignition and start it up again. Also the fault is worse when I have a full car of people, or even a full tank of petrol, which point me towards putting load on the engine.
I have been thinking it was something to do with the fuel delivery to the engine or air sensor etc, as when more power/speed is called for, more air/fuel are required.
The fault will not come on if I am in neutral and Rev the nuts off the car, but I can get the fault to come on every time I put high load on the engine.
I appreciate any help you guys can give me as this is a little frustrating now. I am reluctant to take it to a dealer just yet as I have seen plenty of posts where people have had loads of things changed by dealers with no improvement and I don't want to be ripped off. I would also like to get to the bottom of this and post a follow up to help others as most of the posts I've seen just fade off without any follow up.
Thanks.
Thanks.
