1 - 7 of 7 Posts
Hello,
I am having some problems with my car. When I start the car after it has been sitting parked (weather it is trough the night or just a couple of hours and the engine is "cold") the engine has a strange vibration. Last week it dropped to 0 revs abd stopped. After I let it worm up, for a couple of min, the engine runs right, in traffic it runs ok... the only problem I seem to see is the fact that when "cold", the engine vibrates odd.
Now, I went to the local Ford Service, they told me that the Tester does not go beyond 98 (my model is a 96 Tournier) . Since I cannot see nothing with the tester, I am thinking that maybe the petrol pump/pressure regulator/air induction sensor is not working.
Looking forward to any opinion.
Does this motor have hydraulic lifters.. when last did u check the vitals( oil level, water level and powersteering level l) while u under the bonnet chec al.connector plugs.. feel if intake pipes are solid..just check around for anything odd.
Please tell us the rpm when at idle when cold.
Also you have that problem when a specific exterior temperature occurred, or doesn't matter the outside temp?
Getting on a bit...
Could be something temperature-related, like the sender on top of the thermostat. If it's not sensing the engine is cold it might be under-fueling it, a bit like a carburettor car trying to start from cold without the choke.
if possible post a video (most post via youtube link) of it when it is being odd, it may help us diagnose it better for you. :L
1 - 7 of 7 Posts
