Hi all,
I'm new to the forum and found it very useful in many many ways. Thanks to contributors who take time to read and help others for small bits or big issues.
Here I come to the point. I bought a nice 2004 mk3 estate about a month ago, 2.0 TDCi. I knew I had to reniew the discs and pads (x4).
Ok, car hasn't been on the road for a few weeks before I buy it, so there was quite a few knockings round the front and rear suspensions.
I've changed the 4 discs and pads, took the car to MOT and it flew the test no prob. Now, I could still here knockings and clings when driving above bumps, especially on bad roads. So I decided car could do with new shocks all around and new springs for the rear as the front ones seemed ok to my opinion. I purchased the parts from a Ford dealer shop and started with changing the front shocks. I did the work in 2 days (about 4 hours each side). BTW I'm doing the work myself and I'm not a mechanic.
The front suspensions are now perfect. Brakes are brilliant. Then I started to work on the rear today. And there comes the troubles!
Jacked up the vehicle and securely put it on an unusal stand for more security as when I noticed what work I was involved in, I did not trust the 3 ton stands! So I put a 13 kg gas bottle Under the crossmember right in the middle. with the left rear Wheel on a solid ramp. Beleive me it works well to secure the car 100% as it is solid and won't move a mm... I think it is Worth taking a picture to show on here. Will try and do that tomorrow.
I removed the right spring, then opened and removed the lower shock bolt, opened the lower arm-to-knuckle bolt and started to undo the anti-roll bar drop link bolt from the lower arm and that one wouldn't come off, it even nearly broke my alen key! So I decided to undo it from the anti-roll bar, which I succesfully did. But, because the drop link got stuck in the lower arm, not being able to remove the bolt, I opened the eccentric bolt on the crossmember so as to remove the rear lower arm... It was so tight that it took me an hour to get the nut out of there! Very hard job and very tired at the end.
So, can anyone advise me on what I should do next, please? Should I get a new eccentric bolt and nut although the old one looks OK but very very hard to have it turning in the bolt? Third question, I haven't had a look at the upper shock absorber bolt yet. Any idea if, having removed the rear lower arm, it will be easier to remove or, will I have to face another nightmare to get it out of there? I'm stuck and don't know what to do...
Apologies for being very long this time but I really really needed to ask the right people and, I beleive this is the right place to do it.
Thank you for your kind assistance
Younes
Younes
