usually uneven tyre wear indicates worn suspension parts, or the wheels are out of alignment.
Alignment wise, rear wheels are actually adjustable, i'd advise taking it to a decent wheel alignment specialist, and get the tracking done, the centre locator on the link should take you to the nearest garage with a hunters machine, which is apparently the best machine for having the tracking done on. http://alignmycar.co.uk/
Suspension wise, it could be worn rubber bushes or a broken spring, mondeos can run perfectly well with a broken spring, they tend to break near the top where you can't see them, without a bright torch and the roadwheel off.
