1 - 7 of 7 Posts
· Registered
get someone to weld in a new flexi section? mots car parts factors will stock them. last one i used was for a mates Proton Coupe (we used a clamp on one as it was in a straight section of pipe but theyre available as weld in ones too) and it cost him about £20.
· Don't accept lifts from this guy. :)
Its called the Y pipe, it bolts to the pre cats that make the downpipes on both sides of the engine and the flexi section is part of it making it an expensive part.
You have 3 options-
1 - Find a used one on Ebay or somewhere else who has used parts.
2 - Try Ford for one new and 'if' they have one, take lube cos they will shaft you hard.
3 - Go to an exhaust specialist and they will cut the old one off and weld a brand new flexi section on for about the same as a used one on ebay.
As far as i know, nobody has ever made a pattern part and its a genuine ford part only.
I had one cut off and a new one welded on when it failed on my previous V6 mondeo and also my VR6 Galaxy which also have the dam things welded to the Y pipe.
Its no fun removing the Y pipe, expect rust in your eyes as you are trying to look up at the securing bolts pre cat end while getting a socket on them, if you have the old one cut off and a new welded, they will likely want to have it on the car for positioning, saving you work and crap in your eyes!
· Clever Clauggs
You would definitely hear a blown exhaust that part would sound louder than 'puttting' ,the mesh on mine has come away from the end ring but not blown, I used putty steel and wire to hold it,has past Mot last 8yrs.
Is the section actually blown ? Or is the outer mesh just loose ?
Had this on my Astra once years ago, was loose for years but no consequence as wasn't leaking.
Just a thought
Ta
yeah, the braiding on mine is in a real state, i stretched it out and clamped it down with a jubilee clip a couple of years ago but thats rusted and broken away, i have left it alone since as its not really a problem.
1 - 7 of 7 Posts
