Am wondering if anyone can help give advice. I’ve noticed a few lines on my mondeos heated windscreen are failing. It is perhaps 3 or 4 lines on the drivers side don’t work. The lines either side of these work fine. I presume it isn’t a fuse issue given the rest of the screen is fine. Just wondered whether this was a simple connection issue or the sign of a bigger issue. Thanks
Which Mondeo? MK1, 2 , 3 , 4 or 5?
Temporary moved here..
You need a new windscreen the elements are failing, no repair option.
It’s the mk.4
Cheers for the advice. Thought it might need a new windscreen. I Presume the issue is limited to only Impacting the heated windscreen and has no impact on any other functions.
