Hi,
Can some one help !
MY mk5 fiesta lets water into the boot, the roof headlining gets wet in the rear corner near the hatchback, The water seems to run down the rear trim by the seat belt and then drips onto the wheel arch.
The Garage has sealed the boot/hatchback seal to the body, but it stil leaks....
Any suggestions?
does your rear wash wipe work? pipe disconnected, probably by leak
tail light cluster seals are common on other models, might be on fiesta too.
sunroof drain blocked? (if you have sunroof)
any accident repair on that corner?
