1 - 10 of 10 Posts
ive nearly compleated this mod, done the pedal switches, steering wheel and cruise module, but one of the wires that goes from pin 7 is puzzling me the instructions i have say to connect this to fuse f23 in passengers fusebox, does anybody know which wire i need to splice into to make this connection? nearly got done by a speed camera earlier so would like to finish this off to help save my licence
LED Extraordinaire
Fuse 23 is for the reverse lights, indicators, heated washer jets and aircon.... so a feed from any one of those would do then.
Likes to make the impossible just happen
When I Fitted this mod i put in an in line fuse (15amp) then connected it to the electric windows power cable. That is on the top of the fuse box and is purple, use a volt-meter and someone turning the ignition on and off. All you need is a wire with enough current and goes on and off with the ignition, to be honist there is a wire on the back of your stereo that does that!
I have connected the cruise control to the "C364 pin 1", did I a mistake? :blush: When I read the answers on this topic I had already wired the connection :blush:
Does anybody know if the pin 1 in the C364 connector comes from fuse F23?
Thanks!
1 - 10 of 10 Posts
