1 - 2 of 2 Posts
I've got an adjustable Sparco Strut Brace that I bought for my Mk1 1.8 but never fitted.
I believe it will fit my Mk2 but I don't know how exactly.
I don't have the bolts or the holes in my suspension tops and was wondering if there is a how-to somewhere I could look at.
MEG Admiral
you have to drill the holes mate, and the shorter side is on the drivers side, i went to a garage and they advised the bolts to have nuts attached, which meant alot more work, i drilled the holes then usin a tap and die set, cut the thread to take the bolt and tightened them up and after 12 months they are still tight and no movement in the brace at all :L
just remember not to drill too far through, just take it easy
any probs mate or you need a hand give us a shout as your in peterborough im in dogsthorpe mate
1 - 2 of 2 Posts
