1 - 10 of 10 Posts
MEG Commander
it is possible if you can get all the bits but to be honest, the mondeos traction control is crap so its not worth it in my opinion :L
MEG Commander
can i ask how you wired 3 amps? i want to do this but have no idea how to do all that wiring :}
for the amps i just ran a single thick power cable from the battery to the boot, fitted a distribution box that splits into 4 terminals and run 3 thinner cables from this to the amps, then used another dizzy box for the earth cables, then from the back of my head unit 2 pairs of rca leads(1 for the front 1 for the rear) and a blue remote cable, when in the boot split remote lead into three, pluged front rca into one amp, rear rca into the other and then used rca output on rear amp to run into 3rd amp which powers the sub, if you need a circuit diagram i can put one on here for you
MEG Commander
doesnt seem to make any difference to me.
MEG Commander
[quote name=pete's blue mk2]for the amps i just ran a single thick power cable from the battery to the boot, fitted a distribution box that splits into 4 terminals and run 3 thinner cables from this to the amps, then used another dizzy box for the earth cables, then from the back of my head unit 2 pairs of rca leads(1 for the front 1 for the rear) and a blue remote cable, when in the boot split remote lead into three, pluged front rca into one amp, rear rca into the other and then used rca output on rear amp to run into 3rd amp which powers the sub, if you need a circuit diagram i can put one on here for you[/quote]
that would be really great, look forward to seeing the diagram as i want to do a big install, cheers matey :L :L :L
My real name is Amy
I HAVE T/C ON MY ESTATE.WHEN U REALLY NEED TO TEAR OFF OUT OF A JUNCTION IT DONT LET U.THE CARJUST GOES FLAT AND LEEVES U LOOKIN LIKE A RITE TWAT.SO MINE GETS TURNED OFF AS SOON AS I START THE CAR.WOULDNT WASTE MY MONEY FITTIN IT
My real name is Amy
WHY NOOT GO 4WD MUCH BETTER AND TONS MORE FUN.A BIT MORE WORK.BUT JUST LOOK FOR 1 GOIN FOR SPARES OR REPAIR THEN DO A SLIGHT OPPERATION{SORTED}
I played with the TC at Ford Fair a couple of years ago, 2 runs with it on, 2 without..
Came back at 7.23 & 7.67 with it on, 8.98 & 9.2 with it turned off.. too much wheelspin
1 - 10 of 10 Posts
