1 - 6 of 6 Posts
· Registered
Okey dokey, long story short.
One of my oil burners lamps flickers, sometimes goes out and then come back on. Makes people I'm overtaking on the motorways think I am letting them out !!
Sometimes it goes out and stays out but comes back on when the lights are switched off and back on!!
Getting the impression a 'loose' connection is somewhere as many times the light goes out when going over a severe bump!!
Any direction??
Many thanks in advance
· Big Megger
Easiest bet is to swap the ballasts over and see if the problem moves or not,If a lamp is faulty when it turns off the inverter it wont restrike until power is removed and reinstated.A lot deponds on if they are OEM xenons or from the Fukcasaki Light Company in Shanghai.
· Just me
Do they both go? Does the dash lights dim as well?
· Registered
Ford OEM fit with french electrics !!
Its stopped doing it now, but it shall be back.
Only the NS light. Dash is ok etc.
Ballast is still under warranty so I shall try and get that swapped
1 - 6 of 6 Posts
