i have put the hid kit into my fogs had to use a seperate aux relay and muck about with the foglamp too, but its a lot better, nothing worse than seeing a car with hid white lights an
The Hid 8000k Hid kit, the bulbs are 35w and they run cooler than normal bulbs, so no problems, with the reflectors / light unitsv782st24 said:Thing is, if you put a hotter bulb in then the lens becomes discoloured and kinds melts slightly inside. I know from experience but that was when i went to halfords and got wrong wattage.
These are the ones that I got mate, it also explains / shows the difference in the colour (k rating)v782st24 said:http://cgi.ebay.co.uk/SLIMLINE-HID-UPGRADE-KIT-6000K-H7-FORD-Mondeo-II-Estate_W0QQitemZ270514642026QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item3efbeddc6a
is this what you would reccommend? or you can alter the temperature to change the tint. Or would you go for something cheaper?
have you done it for your main-beam as well as your fogs>?
