Which 20amp fuse there are lots of 20amp fuses?
It's the fuse from the ignition switch to the starter motor/solenoid I think!!!!I have a Ford connect 1.8 van and it has started to blow the 20amp fuse when the ignition is switched on to start the engine.
Thank you for any help
The Capt'n
