Hi,
Recently had a service on my 2.0 Duratec Mondeo(2001) carried out once again at Ford main dealer.They recommended replacement of the rear subframe bushes due splitting/separation.
I read up the various posts on polyurethane bushes and the four wheel alignment check required after the work. I don't have the ramps or interest in lying under my car with bleeding knuckles for a couple of hours so I sent it back to Fords, yesterday, to replace the bushes. Picked it up today, £180 lighter and have a few questions about the job.
They only carried out a "front and rear alignment check" both noted as being "in spec". Is this the correct check to be carried out after the work? Also the steering wheel appears to be offset to the left by a few degrees with the front road wheels straight. Is there an adjustment that they have carried out which would have caused this? Is there a further procedure to realign the steering wheel? Only just replaced all four tyres which had lasted 40000 miles from new with no unusual wear, so I am keen in getting the job done right. Any advise will be gratefully recieved
