Ford Vs Jaguar
578 Views 10 Replies 6 Participants Last post by  gavchard
How come bothe use the same engine but ive not seen any smokey Jags?
1 - 11 of 11 Posts
The jags might have a DPF (diesel particulate filter). They basically burn the soot off but cost £500 or so to replace when they're full/used/worn out. All Euro 5 cars have DPF and they've been an option on commercial vehicles for a while.
[quote name=Welsh Dan]The jags might have a DPF (diesel particulate filter). They basically burn the soot off but cost £500 or so to replace when they're full/used/worn out. All Euro 5 cars have DPF and they've been an option on commercial vehicles for a while.[/quote]
there shouldnt BE any soot in a computer controlled common rail engine with electronic injectors and more sensors than the bloody space shuttle
There will always be soot from an oil burner. Regardless of any fancy circuitry, its got to burn fuel to provide the extra exhaust pressure to drive the turbo to get more air in. The only way to do that is to squirt more oil in!
but if we can set pumps to OVERFUEL, why cant we turn em down when the soot appears? i dont want power so much that i look like the Flying Scotsman on full chat
You could, in theory. If you jammed the turbo vanes to the maximum spoolup position and limited the rpms that you used.
But its more practical to install a DPF, or to clean the inlet manifold and EGR, block off the EGR and remove the CAT.
a dpf only catched smoke/particles emitted by the engine, with a turbo fitted it should be possible to turn the pump flow down (used to do it with a screw on a perkins/montego!) and still have performance using the turbo, a dpf is an admission that the rest of the gizmos dont work, surely a remapper can turn the pump down? so much for the marvellous improvements they have made
i wont mention EGRs and DMFs....
I thought Jagwaaar used different injectors?
My car doesnt smoke, all it does when giving it a boot full is a little puff of dust, nothing more than a petrol really
Some (diesel) x-type jags DO smoke! look at their forums and you will find it is a common complaint, with very similar discussions in finding a cure as can be seen on this forum.
BTW Only 2.2 auto x-types had a DPF as standard, and it was an option on the more recent manual 2.2's. It was not available on 2.0 models.
The x-type is of course now not made.
Jim
Same here!
1 - 11 of 11 Posts
