[quote name=TDCi 160+]Cheers Flash and Mick, between you youve sort of put me off doing it now! :} :} :}
Im going to remove it to give greater access to the cold air feed pipe inside the wheel arch (Mick, mine doesnt have the resonator box either like the V6) so i could re route it for better pick up, and to see what could be done with the intercooler. Like, is it possible to move it down and forwards closer to the front lower grill, and how much room is there available to fit a bigger one?
And Flash, good to see you on here again mate. :L[/quote]
I haven't attempted mine yet Gav,but i would think that with all the plastic feed pipe
removed,from the right hand side behind the radiator you will have some room,i have got a 70mm bore feed pipe to install but i have got to figure out a way of fixing to the space behind the lower grille nearside,i think i am going to have to make some sort of holding plate out
of plastic,and fix that to the existing holes
which held the original pipe work,that would be
an idea cos' they are only held with those push in plastic plugs.
The brackets that Flash is on about he is right
i did fit new ones and they are better built,they
cost about £2 odd for one side and £4 odd for the
other side.
If after fitting your bumper back on you find that
you get bumper droop at the front part of the join
then let me know,i have a little mod that takes
care of it,and you don't need to re remove the bumper to do it,and it will cure bumper droop.
