yes, it's not just ths seals that freeze though, it's the gas/oil inside if it gets cold enough with solidify and then not go through the holes as easily as it should do
after some driving it should ease up as it's got movement, and movement creates heat as a by product so it's sorted itself out
the bigger prolem is if your brakes jam on in the applied position which means you've got to let them warm up before you can actually move :}
