Ok I' ve been hunting round the topics & found a few commenting on Diesel leaking from the solenoid & running onto the bracket & starter. I paid a visit to my local Ford dealer & he quoted me £92 for a new solenoid. After looking at the pic in the haynes Man is it possible to just replace the o-ring or does it leak from somewhere else which means a new solenoid. It seems that getting parts for this car is nigh on impossible down here as the local Motor Factors aren't able to get the parts.
At the moment my plans are:-
1. Replace the 2 fuel pipes from the pipes below the intercooler that run to the metal pipes on top of the engine.
2. Replace the material braided hoses running from the injectors & any other braided hoses.
3. New fuel filter, as I dont know when it was last changed.
4. New injector heat protection washers.
5. Possible new glow plugs( Is it possible to remove these with an ordinary spanner or is it best to do them with a glowplug spanner they sell in Screwfix.)
6. Got a second hand Steering rack from a MK2 ( hope it is the same) just need to get some new Teflon Washers.
7. Since the fuel leak the car seems to be taking longer to start & seems to drain more power, so I'll probably whip the starter off & give it a clean.
8. Possible replace some of the pipes running from the preheater & filter. not sure as these are plastic & have clips which connect them to the various parts. Guess they could be cone if I used jubilee clips on the newe pipes.
Any help with pointing out any issues with the above list would be appreciated
