1 - 6 of 6 Posts
Couch Potato
loverly !, thanks very much for that m8, you've put my mind at rest. I thought it might start leaking later on in life if it worked loose, or worse still, let muck in to the tank. :L
Well if it does start to leak then you need to change the rubber seal that goes inside (pain in the bum to replace)
Glad to be a help
G
1 - 6 of 6 Posts
