1 - 2 of 2 Posts
Hey,
The car chuggs like the injectors are clogged. It gets better after a while then gets worse when I refuel, more so if I change brand (eg from BP to Shell). I've been treating the fuel for a few months with that stuff that's suposed to clean the fuel system, but it persists.
By chuggs I mean the acceleration not really kicking in, especially when a speed boost is needed or when trying to go up hills, even if a slow gradient.
Any ideas?
About a year ago the same thing happened and I got the waste gate valve changed and some sensor replaced. Should I use an engine flush?
thank you kindly for the help
As you mention turbo, I'm guessing it's a diesel.
To check the injectors a leak off test will tell you a lot about injector condition. Additional es may improve things but won't do anything on injectors that are mechanically or electrically dodgy.
A good performance and drivability tech would be your best bet, but try the simple things yourself first. Do a full service including fuel filter, clean the MAF sensor, map sensor and inlet air temp sensor (some diesels don't have a maf).
Personally ally I wouldn't bother with an engine flush. I confess I used Wynnes diesel engine flush on mine before I changed the oil and it did make the oil stay completely clean for a bout 800 miles or so, but it's not the first thing that springs to mind with a performance issue.
Does the car have a variable nozzle turbo? Could be the vanes stick g or a bad actuator. Search the mk3 Mondeo forum for details.
A diagnostic may help by revealing any trouble codes stored. Sometimes there may be pending codes that haven't thrown a light yet.
1 - 2 of 2 Posts
