I'VE JUST GOT A GALAXY. THE STOP WARNING LIGHT AND THE TEMPETURE WARNING LIGHT IS ALWAYS FLASHING. I DROVE IT A COUPLE OF HUNDRED MILES AND IT DROVE GREAT. HOW DO I GET THE WARNING LIGHTS OFF??.
You need to trace the source of the problem, if they keep coming on then the fault is likely to be ongoing.
Resetting the light will likely just take if off very briefly.
You need a code a code reader to know where to start. Just because it points to one part though don't assume
its that part, its just a starting point. You need to think further back.
What could cause that part to give a bad reading etc. Part maybe faulty or the wiring to the part maybe faulty
or another component giving bad data.
If its a temperature warning you need to check the engines real temperature, dont trust the gauge on the dash.
That could say normal and yet it could be overheating.
THANK YOU. I WILL LOOK FURTHER.
WHAT I CAN'T UNDERSTAND IS I DROVE IT OVER 200 MILES WITHOUT A PROBLEM AND THE WARNING WERE ON CONSTANTLY.??
Someone suggested to me that there is a reset button behind the water bottle. Is that correct?
