Gearbox aids
812 Views 2 Replies 2 Participants Last post by  davetherave1
Would anyone recommend any gearbox additives. The gearbox on my 'w' reg 1.8 td mk 2 works fine but is very notchy. Cheers Dave.
The correct spec on the 5 speed MTX75 is no additives ,the overall spec was changed around 2000 and the straight Ford 'honey' lube is the current spec or Royal Purple 'Syncromax'...Some others can be used but those are the main two.
Thanks for reply. Will try a refill and see if things improve. Cheers.
