I have a problem with my Ranger Wildtrak 3.2 MY 2016.
Getting fault codes for all glow plugs being open cct and think it is related to the control module. I understand the module is part number AB3912B533AB and ordered the part from Autodoc. On receiving the part it's clear they sent the same part number but its a different version. As per the picture below it seems there is more than one version of this part and I'm struggling to find the one I need (top image). Can anyone help me source one or advise an alternative as Ford want £140 !!!
I did some digging and the BB seems to refer to the complete module including bracket and fixing (as a kit). From here its appears as though there are sub numbers for the 2.2L 4cyl and 3.2L 5cyl though I can't for the life of me find a suppler of the one I need other than FoMoCo and their piss taking prices.
Not too keen on second hand but might have to go that route.
Can you connect the 'wrong version' (with some bits of wire), see if that clears the code, otherwise it may point to a wiring fault rather than a module
Totally feasible but I don't have any schematics. A wiring fault is possible and I'll bell everything through if I have to drop £140, I was hoping for a quick £40 fix or simply return the part if it didn't clear the issue (lazy I know but quick).
That said I'll open the thing up and attempt to repair myself before sending £140 to FoMoCo.
