I have replaced the four glowplugs due to the light coming on at startup. light still comes on with 4 new plugs fitted any ideas
The glowplug light is like an engine management light. It's not a warning
about the glowplugs.
Flashing glowplug light is limp mode, a reduced power get you home mode.
You need an OBDII reader £20...ish. Make sure its Ford compatible ans uses
Forscan software/App. Fault codes should be stored.
many thanks for the prompt rely and for the info
