1 - 16 of 16 Posts
Spider Pig, Spider Pig
Need some help please,
got a right clucking noise from the pass side and check suspension and spring, amd drive shaft and cv joing and wishbone arm and bushs, and then grapped hold of the anit roll bar and thats the noise i hear when the car slows down even when changing gear.
Anyway tried to change the bush's tonight and thats a no no job for me, but while putting the inner arch cover back on, i knock another part of the arch cover and heared something drop out.
This got be very worried when i found what had dropped but cant find anywhere were it has come from. This is from the pass side. its just over half an inch wide.
for got to say its a 99yr TD mk2
MEG Admiral
poss an old bumper fixing? im sure i have some in my shed from my old mk 1
Turbo Boost Me!
I was gonna say that but after looking closer I decided its not, Its a bolt and the head has sheared off for some reason, No idea where its from though
The threaded part would be further along the bolt if it was a pinch bolt. Looking at those pictures the threaded part starts almost straight after the head.
MEG's Resident Removal Man
Is it the caliper to hub bolt??
jcth1
TDDI Buff
jcth1
no its not it looks like a pinch bolt for the wishbone ball joint.
Discussion Starter · #12 ·
Well the garage have had a good look round and cant find where it has come from, but the knocking noise was the rear engine mount which was shagged as he told me, and both wishbone arms need doing next year
The never ending project is close to finishing
I'm sure you'll find its the lower arm bolt thats bolts to the hub, this would explain the clonking noise you are getting as the lower arm will be moving, IIRC think you'll its a T55 socket
MEG Captain
It's a T50 socket, changed mine the other day :L
1 - 16 of 16 Posts
