It has happened about couple of weeks ago as there was burning smell from right-hand rear wheel - smells like coming from a grinder!
My friend has checked it out and found that the lever (dunno what to call it) was struck, won't come loose so he applied WD40 to it and pushed it forward/backward to loosen it. It worked fine for about a week then it came back, getting worse now.
So I took the wheel off and did the same again with WD40...this time, it is still bit stuff. What should I do? Take it off and inspect inside?
Gary
Gary
