1 - 8 of 8 Posts
is it dear to have a head shot blasted.ive stripped my head naked,to get it cleaned up ready for my turbo conversion.ive also tapped and died my head to take the escort rs turbo exhaust manifold. :D
Not to sure about the costs for shot blasting.
But I had a head off a puma 1.7 zetec, treated to a acid bath & it came out as good as new :)
MEG Captain
just a small point , it wouldnt be shotblasted , there would be nothing left of it , it needs vapour bead blasting , i wouldnt want to pay more than £20 if it was me :L
Sand blasting would clean it up too, do you have a mate who works in a factory, and they have one there.
Window licking mong
why not send it to cylinder head developments and get it ported and flowed, and they will clean it up anyway! cost is £350.
and you could get a big valve conversion at the same time, not cheap but would give a bloody nice power gain (i got one waiting in the garage to be done lol)
andy weston is a top bloke i would go down the route phil said and have it sent to cylinder head developments and head mods make the most gains on a turboed car with a set of cams with pulleys which he also does but dont go to mad with the spec of cam will mess the balance up ok
Turbo Boost Me!
Shot blasting or sand blasting a head is not a good idea, I usually take mine to the local engine builders and ask them to hot wash it, It just goes in a large vat of hot chemicals for a day or so, comes out looking clean and new.
How can you tap and die something, You either tap it or die it but not both.
A tap cuts threads into a hole,
A die cuts threads into a rod/bolt.
1 - 8 of 8 Posts
