1 - 2 of 2 Posts
mondeo less
Got a problem with a headlight (main beam) not working took the bulb out that is ok. so i checked the multi plug that is ok so i swaped the lights over (near side to off side)and that worked ruling out the multi plug on the car. So now where. help :thankyousign:
did you try the bulb that you think has gone in the other side? it might 'look' ok but the filaments do not always break. Also, you can perform a continuity test on the suspect bulb.
1 - 2 of 2 Posts
